Running temp
My car seems to have heat, pretty good heat too...however my temp gauge barely goes above 1/4...if my heat is hot does that mean my engine is at running temp...what could be causing my temp gauge to show 1/4, but my heat to actually be hot..
Re: Running temp
Operating temps should be 3/8ths read from the guage. Replace your engine coolant temperature. A bad one will be telling the PCM and gauge your engine is cool, when it really is not (thus you have good heat).
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man |
Re: Running temp
the sensor might have broken down.You should go to a service and check it out
Re: Running temp
No need to bring it anywhere. New sensor is 10 bucks and well worth it to be replaced.
Re: Running temp
yes but if you don`t know how to do it it`s not that easy.
Re: Running temp
Re: Running temp
RC1488 -Your sister has skill
. headscratching - hope you can handle it. Cheers |
Re: Running temp
not to hijack the thread, but im 14 and i changed a coil, plugs, wires, oil, and filter on my car. and thats just on my car.
Re: Running temp
As long as you have a deep well 13mm socket & ratchet, can afford $10, have 10 minutes of free time, and the slightest inkling of mechanical aptitude, you can replace the ECTS.
It is a very easy repair......easier than an oil change on these cars IMO.
My rides: 2007 Chevy Equinox LT FWD 2018 Chrysler Pacifica Touring L "If women don't find you handsome, they should at least find you handy!" - Steve Smith (Red) |
Re: Running temp
When mine went bad the auto transmission temp sensor went around the same time. I believe they are the same type so it kind of made sense. Not saying to change it, but if you get a check engine light and the code leads to the transmission. Then you may want to remember.
