Old 01-04-2010, 11:56 PM
mexiNAMEDsqueak mexiNAMEDsqueak is offline
Part inquiry/trunk
So I was loading a bass amp in my trunk and I broke a metal bar that supports the trunk, but I have no idea what the part's called. I was wondering if anyone could help out.
I have an 03 cavalier.
Old 01-05-2010, 04:54 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Part inquiry/trunk
If you mean the spring/torsion bar that holds it open/helps lift it, just ask for "the spring that holds the trunk open". Anyone should know what you mean by that.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-19-2010, 09:22 PM
Thanks man. I've been having issues with trying to translate what the fuck it did for some reason lol
