Old 01-04-2010, 06:31 PM
termite88 termite88 is offline
Random Misfire, 98 K1500 5.7
I have been having a random misfire with my 98 K1500 5.7. The O2 sensors have all been replaced within the past 2 years and fuel filter replaced every other oil change. Also have done a regular tune up of plugs, wires, cap, and rotor button. The code it is throwing is P0300 I don't know where to look for the cause. Most people say O2 sensors but I have also heard EGR valve. I have the OBDCOM software and interface cable to hook up a laptop to the OBD port and monitor various sensors. What should I look for as a clue of the cause. Any help would be greatly appreciated. Thanks- Ben
Old 01-04-2010, 06:52 PM
maxwedge maxwedge is offline
A990 racer
Re: Random Misfire, 98 K1500 5.7
Do you actually feel the misfire and under what conditions?
Old 01-04-2010, 07:18 PM
I can feel the misfire very clearly. it starts out as a slight shudder and progresses until you can feel the entire truck shake. It usually occurs when it has a hard load such as a long steep climb but has happened on flat roads as well both while accelerating and decelerating.
Old 01-04-2010, 08:07 PM
2000CAYukon 2000CAYukon is offline
The distributor drive gear can wear and cause a random misfire. Pull the cap and see if you have excessive movement.
Also check the fuel pressure.
//2000CAYukon
Old 01-06-2010, 03:30 PM
mikasa mikasa is offline
Most common failure for p-300 is wrapped plastic intake. On cold start there is gap for entering unmetered air into engine.You can spray carb cleaner and look at upstream o-2s for rich condition. 0.80-0.90 V, or use water and look for steam coming from exhaust, and rough running.Repair procedure here.
http://www.d-tips.com/General/Articl...fold%20repair/
Hope this helps.
Please post if this helps, for other members.
Old 01-11-2010, 06:47 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
This kinda sounds like a fuel pump to me. I had same problem, where truck would slowly lose power as I climbed long hills, and it was the fuel pump. I tried cap, rotor, plugs, etc - just like you. I believe I had exact same code, but can't remember. If you replace the pump, make sure to use OEM pump. Some of the aftermarket brands just don't last at all.
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
