Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 01-04-2010, 06:40 PM   #1
kwagner_51
No heat driver's side
1994 Dodge Ram B250 318 I can't figure out why the driver's side doesn't have heat. The heat on the passenger side is hot!!
Is there a vent for the floor that I don't know about on the driver's side?
Is there a way to connect a hose from the passenger side vents to the driver's side floor?
I am freezing and need your help ASAP!!
Thanks!!
Karen RN, Auto tech
kwagner_51 is offline   Reply With Quote
Old 01-04-2010, 07:50 PM   #2
alloro
Re: No heat driver's side
The duct work under the dash should blow heat to both sides. It's possible a previous owner blocked off the drivers side (as some do) because long drives tend to burn the right foot even though the rest of the van is still cold. You're just going to have to get under there and take a look.
alloro is offline   Reply With Quote
Old 01-04-2010, 08:25 PM   #3
kwagner_51
So am I looking under the van or under the dash? Do I remove the engine cover for access?
Thanks!!
Karen, RN, Auto tech
Old 01-05-2010, 10:24 AM   #4
alloro
Look under the dash for the black ducts that blow the air downward. You don't have to remove the engine cover, but doing so gives you a much better view.
