Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-04-2010, 05:33 PM
yankeefan4ever yankeefan4ever is offline
Low Coolant and Overheat but no leaks.
I just bought a used 2002 Ram 1500 w/ 4.7L v8 engine. Only been driving it for 3-4 weeks and the coolant was topped off when I picked it up. Last week my "check gauge" light came on because it was overheating. When I got home and checked, the coolant was really low. I haven't seen any puddles or noticed any leaks since I've had it. I put in a whole gallon of 50/50 mix (it's all I had at home) and it was still low. It's at the shop right now and mechanic said he topped it off, put pressure on it and can't find a coolant leak? A quick online search brings back results that scare me...head gasket. I mentioned the head gasket to mech and he said it would be smoking badly out the exhaust and the oil would show signs which he said were not happening. I only have a week left on 30 day warranty so I need to confirm a head gasket problem sooner rather than later, what should I be asking mech to check, what should I look for myself when I check out the truck tomorrow at the shop? Is there any way to confirm head gasket problem without taking the entire engine apart??? Please help.
Old 01-04-2010, 09:08 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Low Coolant and Overheat but no leaks.
I put a big piece of cardboard under the engine of my '97 Bravada and started & brought the engine up to normal operating temperatures then shut it off and found some antifreeze leaking from the rear area of the engine...leaky intake manifold gasket.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-05-2010, 09:25 AM
ricebike ricebike is offline
take it back to the place with the warranty ASAP!
Old 01-05-2010, 11:43 AM
scjibberjaws49 scjibberjaws49 is offline
take each spark plug out one at a time and see if any of them are wet with antifreeze/coolant ! if so then the head gasket is bad on that cylinder, turn engine with plugs out see if anything blows out of any cylinder, let set for an hour or so and turn engine again see if anything blows out of any of the spark plug holes ! best to check compression on each cylinder if you have a compression gauge !! if compression is very low on one cylinder there is your problem. ( head gasket ) Danny
Old 01-07-2010, 08:23 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Change your oil, and have an oil analysis done...I use Blackstone Labs. They'll tell you if you have coolant in your oil. 1 week might not be enough time to get the test kit, send it in and have it done, but you can change the oil right away and save a small sample (in a pill bottle or something, they only need 3 oz I think) and send it in when they send you your sample kit. They're pretty quick on response, usually within 2-3 days, and they can send the results by email.
Also, check the inside of your tailpipe, if you're leaking coolant it may be wet and smell slightly of coolant.
In any event, take it back to where you have the warranty right away - make sure they know about the issue and make sure that it is well documented... DON'T let them work on it without making a computer note or noting the problem on some paperwork which you have one copy of. Tell them you've sent for an oil analysis and will share the results when it comes in.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
