Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-04-2010, 05:35 PM
Slashldr's Avatar
Slashldr Slashldr is offline
Angry fuel pump problem
Ok so i have a 1988 trans am that had a 305 tpi and i swaped the engine to a 350 carb and the fuel pump has to much psi so i need to cut the wire to the fuel pump and put another one on there but i want to make it easy as possible so where can i put the new fuel pump
Old 03-02-2010, 11:50 PM
steve57 steve57 is offline
Re: fuel pump problem
you can use the same pump if you put a fuel pressure regulator on it and a just the pressure down to where you need it
Old 04-01-2010, 11:18 PM
malletslinger's Avatar
malletslinger malletslinger is offline
steve's idea sounds good to me...if the pump is pushing too much fuel, than a fuel regulator should do the trick
