Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 01-03-2010, 09:44 PM
tlknv tlknv is offline
How to replace upstream O2 sensor
I need to replace upstream O2 sensor on my Subaru Forester L 1999. Do I need to remove the shield under the catalitic converter or it's possible to unscrew the sersor with some kind of "socket" wrench ? All the bolts which hold the shield are very rusty and I'm not sure if it's possible to unscrew them.
Old 01-03-2010, 10:10 PM
danielsatur danielsatur is offline
Re: How to replace upstream O2 sensor
The upstream H02 sensor is the sensor closer to the exhaust manifold, it's the size of a spark plug, and canbe taken out with a wrench.
Old 01-03-2010, 10:28 PM
Danielsatur,
Thank you for the answer. I just want to make sure that it should be some special/socket wrench. Shouldn't it ? It's impossible to unscrew upstream O2 sensor with any regular wrench.
Old 01-03-2010, 10:38 PM
Disconnect H02 sensor, thread a good boxed end wrench, and turn counter clockwise to remove.
Don't forget to put anti sezie compound on the threads of new sensor.
Old 01-03-2010, 10:58 PM
Thank you, Danielsatur.
Old 01-04-2010, 10:47 PM
Danielsatur,
Thanks for the info.
Old 01-04-2010, 10:51 PM
Dear moderator,
It's my third attempt to just say thanks to the author of the answers.
Old 03-26-2010, 08:53 PM
whopperdad whopperdad is offline
if too rusty try using aero-kroil or pb blaster let sit a little while
Tags
catalytic , oxygen
