Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 01-03-2010, 05:14 PM
troche08 troche08 is offline
Question How to remove oil pan?
Hello everyone; my first post. Ok I own a 1975 chev. Nova: 250 eng. 4.1 with a 3 speed manual. My oil pan has been leaking for a while and I have decided to remove oil pan, replace gasket, replace motor mount clean oil pump or else. I would like to know how to remove oil pan. Will removing trany, along with fly wheel, and clutch be a good or easier option. Please advice as to best option. Thanks.
Old 01-04-2010, 08:31 AM
MrPbody MrPbody is offline
AF -Advisor
Re: How to remove oil pan?
Consult a factory service manual for the "step by step" instructions. The "list" is rather long...
Jim
Old 01-06-2010, 04:52 PM
Jim
Hi, thanks for your responce, however the chilton's repair manual for chevy II nova 62-79 does not address the issue. Take care.
Old 03-02-2010, 12:48 AM
Dennis321 Dennis321 is offline
You'll need to undo the motor mounts and raise the motor a little bit for clearance. That's the biggest thing you need to know. Outside of that, be sure to remove the entire oldgasket, clean completely and make sure the new gasket goes on evenly and doesnot slip or squeeze out during installation of the pan. It's a good idea to use guides when installing thepan to keep both hands free during installation. The guides thread into the holes for the pan bolts and let in hang in place while you install the bolts. Overall it is a straightforward procedure, but takes time. Good luck.
Old 03-02-2010, 05:58 PM
Thumbs up Re: How to remove oil pan?
Hi, thanks very much for your responce. Point well taken.
