Old 01-03-2010, 03:38 AM
jeremyjjj jeremyjjj is offline
99 cavalier 2.2 ohv overheating
I have a 2.2 that overheats the water pump, thermostat, has been replaced i also tried to bleed out. the radiator never gets hot. Just wont circulate water. i did a compression check pressure was good. i just cant figure why the thermostat wont open.
Old 01-03-2010, 07:43 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 99 cavalier 2.2 ohv overheating
Try loosening the thermostat housing bolts until you get some coolant coming out, then snug them back up. Another member found that this was the solution on his, you can probably find the post by searching.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-03-2010, 08:02 PM
danielsatur danielsatur is offline
Did you put the thremostat in right?
Old 01-03-2010, 08:16 PM
J-Ri's Avatar
They only go in one way and rotation doesn't matter.
Old 01-03-2010, 08:32 PM
Sometimes you need to use a little water pressure through the coolant system to force the air pockets out.
Old 01-12-2010, 12:25 AM
Well i drilled a small hole in the thermostat maybe 3/16" and finially got the air bled out must be a poor design. works good now.
Old 01-12-2010, 03:40 PM
consultIII consultIII is offline
on cavaliers coolant flow is from the head to the heater core back to the thermostat. if your heater core is blocked the engine will overheat. if all other diagnosis turn up nothing bypass your heater core.
Old 02-12-2010, 06:11 PM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
I didn't realize that. What a stupid *$
Old 02-12-2010, 08:05 PM
there is a bypass designed into the system but the overheat still occurs when the core flow is stopped....clamp off the outlet and see what happens.
Old 10-06-2010, 09:30 PM
QCubed QCubed is offline
I recently bought a 99 Cav which has the standard instrument cluster. The temp guage has a low mark, high mark, and a red zone. I notice that while driving the temp guage stays right in the middle of the low and high marks but will quickly creep up to around 3/4 or 4/5 between the two marks in stop and go traffic or long idles. One particularly warm day, stuck in heavy traffic for construction, I watched it creep up to very close to the red zone. Note: It has never gone into the red zone. (The car does not have AC and I had turned off the fan for the air into the cabin.) Since I don't have much prior experience with this vehicle, I'm wondering: is this normal? Or am I heading for a problem that I could perhaps nip in the bud right now? With thanks to all who reply.
Old 10-12-2010, 02:25 PM
Bump...No replies yet...Anyone?
Old 10-18-2010, 07:37 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Wink Re: 99 cavalier 2.2 ohv overheating
My 96 2.2 runs on the high side also...just make sure at some point the electric fan comes on.... What I did was install a remote switch that lets me turn on the fan before it gets too hot...if there is a problem with the cooling system, this will not help. Make sure the system is flushed and cleaned regularly. Also back flush the radiator to remove bugs, that will decrease air flow....If something is major wrong..it will go red or HOT...
Cheers Mate.... Have a tinney on me !!!
The Following User Says Thank You to Helmuth48 For This Useful Post:
QCubed (06-01-2011)
Old 10-25-2010, 03:07 PM
Thanks Helmuth! I will do as suggested and post an update soon.
