Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 04-10-2003, 02:26 PM
goatrider goatrider is offline
no heat - brrrrrrrrr
My 93 Villager's heat stopped working. I checked the radiator, fluid was low. Found a leaky hose. Fixed that. Still no heat. Any ideas?
Old 05-29-2003, 06:44 AM
armin4 armin4 is offline
Send a message via AIM to armin4
check heater hoses, check water pump
IF IT DOESN'T HAVE AN ENGINE AND IT'S NOT RATED XXX, IT'S NOT A SPORT!
CARS:
1998 Ford Mustang GT
1994 Mercury Villager "Nautica Edition"
Old 09-01-2003, 11:46 AM
slipguy slipguy is offline
no heat brrr
i would have to assume water pump was working or engine would overheat. Hence logically, one has to see if hot water is flowing thru heater core. This leads to one of two things: either the core is clogged or the switch that opens the valve is stuck shut. I would find a way to bypass the switch so that the valve is fully open then disconnect the two hoses and try to shoot a garden hose thru one of them and see if any thing shoots out the other. If it does, then switch is bad. If valve wont open no matter what, then valve is faulty. I have not gone looking for the heater hoses on my 94 so i am not sure how accessible they are.
Old 10-18-2003, 01:33 PM
treetrashish treetrashish is offline
one word: thermostat
Old 12-28-2003, 10:37 PM
eltigre eltigre is offline
Re: no heat - brrrrrrrrr
You may just have air in the system.....when you replced missing coolant did you follow procedure to fill it with coolant? There's a specific procedure to follow; reason being that the heater core is quite high compared to the hoses and cooling system hence leading to air in the system.......
'01 Cougar No Air flow 99% of the time need heat and live in WI goldsun767 Cougar 0 10-15-2010 04:27 AM
No heat when not on throtle... COLD... rmwilson Problem Diagnosis 13 12-26-2009 01:09 PM
2000 LS NO POWER TO AC/HEAT controller Cassious Regal 1 12-17-2009 06:29 PM
TIP: Smell When Run Heat on FULL... Intuit Escort 7 11-14-2009 04:11 AM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
