Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-02-2010, 05:59 PM
pdlandry pdlandry is offline
98' Ford Crown Victoria electric window problem
Fixed it less than a year ago....replaced cable/track assembly.......... Advanced Auto replacement part didn't last long....... pretty sad
Would like to buy better part....... any advice?
Old 01-03-2010, 02:45 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 98' Ford Crown Victoria electric window problem
Have you tried Dorman? Or was that the part brand. We either use OEM or Dorman on our fleet.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-03-2010, 02:59 PM
mreynolds mreynolds is offline
I have been working with a CV fleet for about ten years and OEM is the only one we use.
Old 01-03-2010, 08:37 PM
Brand name "JUNK" ...... lol......... I will try Dorman this time
THANKS
Old 01-03-2010, 09:20 PM
danielsatur danielsatur is offline
I have noticed bad window regulators plagued all car types!
When opeing + closing doors make sure the windows are all the way up or down.
The cable on the window regulator will bounce during the slamming of the door, the cable will bind up, using the electric window will cause it to break.
Old 01-05-2010, 07:49 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
I have replaced several regulators with the cheap 15.00 aftermarket ones off e bay with out a problem.
Mike aka JYD
Old 01-21-2010, 10:16 PM
Bought Dorman window regulator...... installed ...... window doing same
goes down easily but won't go up.
Sounds like the motor is working/turning but also sounds like its slipping???
Will go up with some help with pulling up on window.
TOTALLY CONFUSED NOW
Motor problem??
Old 01-24-2010, 02:08 PM
Those three clutch bushings inside the motor could be bad also. The motors will slip bad if they are all chewed up.
Mike aka JYD
Old 03-20-2010, 02:41 PM
where are the bushings located and how to replace?
