Old 01-01-2010, 09:42 PM
Tony241 Tony241 is offline
2006 GMC Sierra Denali transmission problems
I also posted this in the GMC forums where it belong,but I figured the trannys are pretty much the same on GMC and Chevy.I have a 06 GMC Sierra Denali AWD that had a new tranny installed 5000 miles ago by local dealer.A couple weeks ago while cruising rural roads 40-50 mph,I get a Vibration from what I think is the tranny.It only happens low rpms,1500 or so and in top gear.If I give it a little gas it goes away.but you can feel it through the hole truck,even my wife noticed too,and she thought it was washboard bumps in the road due to winter,which is a pretty good description I might add.They best way I can describe it would be to compare it to the feeling when a throw out bearing goes in a stantard vehicle like my 82 Mustang. It that same feeling when you let out the clutch and just as it enganges it shimmies a little bit,except in my truck it keeps happening when your at a constant low rpm in drive(or overdrive I think it is) .My truck is an automatic. Its also the same type of symptom I had in my 2000 Ford E350 when a coil pack was on its way out,just not as strong of a sensation as that.Kinda like a little bucking or something,but mat it and it goes away,but let of the gas and lug the motor and its back.I know its tough to explain somethings to others,but I tried my best.If anyone has any ideas it would be great or if you have any questions to help diagnose it,lets hear them. It would be easier if the check engine light would come on and throw a code.Thanks.
Old 01-01-2010, 11:53 PM
troy1 troy1 is offline
AF -Advisor
Re: 2006 GMC Sierra Denali transmission problems
Just because there is no CEL does not mean there is no stored DTC. Take it back to the dealer and get it checked out
Old 01-02-2010, 11:00 AM
j cAT j cAT is offline
with that speed it may be the TCC not droping out.
I would bring it back for drive train codes...see if they will get this and give it to you to post back the results of the codes.
Old 01-02-2010, 03:44 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If it was a FACTORY REBUILT TRANSMISSION it still should be under warranty,
At least 3 years or 50-100K miles.
Let the dealer check transmission under warranty.
MT
