Old 01-01-2010, 06:09 AM
McLin's Avatar
McLin McLin is offline
Replace Ball joint
Hi,
my Lumina 98 3.8L LTZ need to replace the passanger Ball joint.
Did anybody know if I need some speacial tools? Did can anybody down write a short step by step what is todo?
Happy new Year @all!
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 01-01-2010, 06:45 AM
maxwedge maxwedge is offline
A990 racer
Re: Replace Ball joint
Check the how to at autozone.com. repair guides, register and go to suspension/steering.
Old 01-01-2010, 07:03 AM
McLin's Avatar
thx, but these instruction I had read, but I have problem with the part where stand I should remove the lower control arm, for these steps I need a special tool...
So I must really remove the lower control arm?
Best regards McLin.
My Lumina
Mileage:
Old 01-01-2010, 08:11 AM
svotta svotta is offline
if the ball joint is original then it might be riveted on. you dont have to remove the control arm on mine at least i didt. i cut my rivets off drilled the new holes and put the new one in
Old 01-01-2010, 11:26 AM
A990 racer
Thumbs up Re: Replace Ball joint
Correct, it is easier to grind the rivets off out of the car but it can be done on car, an air chisel is how we do it.
Old 01-01-2010, 11:57 AM
McLin's Avatar
Ok one more qestion. I readed in Haynes Repair Manual that I must use an two arm puller to remove the ball joint from the knuckle, but I did not need an tool for installation, that make me confuse
Best regards McLin.
My Lumina
Mileage:
Old 01-02-2010, 08:04 AM
A990 racer
Not true ,once the rivets are out it will drop out. Chuck the Haynes, useless!!
Old 01-03-2010, 03:31 PM
unboundtrucker unboundtrucker is offline
Send a message via Yahoo to unboundtrucker
I had to use a "pickle fork" on mine when I replaced 'them'. I wouldn't suggest replacing one side only.
Old 01-04-2010, 03:31 PM
McLin's Avatar
So I understand what u told me is that I just chisel the rivets out?
If I dont have an air chisel is there place to hammer with chisel the rivets out?
Best regards McLin.
My Lumina
Mileage:
Old 01-04-2010, 06:42 PM
A990 racer
You will see the rivet heads facing up on the top of the lower arm around the ball joint, chop them out.
Old 01-05-2010, 06:36 PM
rhandwor rhandwor is offline
If you don't have an air operated chisel a small angle side grinder will work. I use an electric grinder and grind the head off against the old ball joint. Use a hammer and punch to drive out the rivet.
Old 01-14-2010, 12:32 PM
McLin's Avatar
If I do not remove the lower control arm, did I need to do new wheel alignment?
What for values did I need?
Best regards McLin.
My Lumina
Mileage:
Old 01-14-2010, 08:16 PM
A990 racer
Not necessary.
