Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-31-2009, 07:14 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
EGR question
I got an LM1 350 to swap into my caprice. I was cleaning it up and noticed it doesn't have an EGR unlike my 305. What does the EGR do? Is it just emissions garbage?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-01-2010, 01:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: EGR question
Exhaust Gas Recirculation. It cuts down on NOx emissions by recirculating some exhaust gas into the engine to lower peak combustion chambers.
NOx mixes with hydrocarbon emissions in a photochemical reaction (sunlight) and creates ground-level ozone. Remember, ozone while beneficial in our atmosphere is actually quite toxic.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-01-2010, 10:56 AM
Blue Bowtie's Avatar
Registered Offender
Re: EGR question
The other benefit of EGR is that in reducing combustion chamber temperatures you can often increase ignition timing slightly and produce a bit more power from every ounce of fuel.
Old 01-01-2010, 05:59 PM
j cAT j cAT is offline
Re: EGR question
was this 350 a boat engine? with no EGR you will need 93 octane..
as mentioned the egr is open above idle to blend some exhaust gases into the combution chamber.. with this occuring the combustion chamber has less oxygen this then reduces the temperature..
this lower temp allows the use of 87 octane.the egr ports also help heat up the fuel being drawn into the engine, as this port is directly below the throttle plates of the carb..
with a boat engine this would not be needed because the cooling water would not get this into the high temp area as a land motor vehicle..
you have cold water flowing into the heads....not high temp coolant..
also the engine in the boat in under a constant high load condition..
Old 01-01-2010, 11:07 PM
bhw33191's Avatar
Re: EGR question
No not a boat engine. From what i've heard the LM1 is the typical car 350, but the guy i got it from said its the truck version, if there is such a thing? He bought it straight from a Chevy dealer and used it in his CK Blazer so i'm positive its a practical engine and doesn't use 93 octane. I looked up the part number on this engine (10067353). It is a car and light truck replacement. So maybe the guy had no knowledge of the need for an EGR and never put it on? If it turns into a problem i can always just install one later. But the thing is, I've heard something called an "EGR delete" before. I'd assume one would only "delete" the EGR to gain HP right?..I'm guessing thats only used in high performance situations correct? So yeah, maybe i'll have to install one later or use the one from my 305
Old 01-02-2010, 11:38 AM
Re: EGR question
removing the EGR is not going to increase power..I never heard of an egr delete in a passenger vehicle..you will need 93 octane with no egr...because it will have pre-ignition [ping like hell]
call the boat yards near your you and tell them what you got for an engine ...this is used as the prefered boat engine...ask them about how the egr is missing see what they say.
