Old 12-31-2009, 07:35 AM
skylakaylah skylakaylah is offline
Sub, mabye amp issue
My car has a 4 channel amp where i run my front speakers and amp though. Lately, the sub cuts in and out (seems like it happens when i hit bumps) I got a car place check connection and they reckon my amp was faulty, so i get a new amp and problem is still not fixed.
Fuses are fine. Connections to amp are fine. Got one of those alitmeters out and it seems like amp is only getting a small amount of power.
Any ideas? Thanks
Old 01-01-2010, 03:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Sub, mabye amp issue
chech the connections where the the fuse holder is, the fuse may also be mostly blown
Old 01-04-2010, 05:45 PM
cramer_77 cramer_77 is offline
check the continuity of your power wire, just do a simple ohms resistance test, thats where i would check, also you might check your ground, you wouldn't believe what a bad ground connection would do.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
