Old 12-31-2009, 02:04 AM
ymadmacks ymadmacks is offline
97 Mark VIII/Cobra motor ticking
I drive a 97 mark viii with the 32v DOHC. I overheated it and now have a VERY light "tick" that is random when it idles down. It does not sound rotational, more like its from the bottom end. but the actual noise is so light i can almost pinpoint it on top. I tried a stethascope on it and still couldnt find the exact spot. I was wondering if anyone else has encountered this with the cobra setup. is it a bearing? or possibly a lifter? I dont want to say its the bottom cause it is such a light noise, but i dont want to rule that out.
Old 12-31-2009, 02:07 AM
Re: 97 Mark VIII/Cobra motor ticking
Also, the sound seems to get quieter when the car is jacked up in the front. And i just did an oil cleanout and new oil, filter, and thermostat and the noise did not change
Old 12-31-2009, 01:37 PM
danielsatur danielsatur is offline
It could be a secondary cam chain tensioner, see http://www.automotiveforums.com/vbul...d.php?t=954555
Old 03-23-2010, 01:08 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
This is true and I have also heard that the cam phaser can cause ticking on the motors as well. My 5.4 has had a slight tick at idle that been there for almost a year now with good oil pressue and sure.
Since you over heated the motor, have you done a compression check yet?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Tags
32v , cobra , dohc , lincoln , viii
