Old 12-30-2009, 10:47 PM
dnmir54 dnmir54 is offline
Smile inst panel tailight fuse keeps blowing
this is for a1996 s10 pickup blew inst panel lights and tailight fuse ,replaced it and it blew after 30 seconds.replaced it and it blew again immediatly when we turned on the headlight /tailight switch
what could be the cause what should i check for
any help would be appreciated
Old 12-31-2009, 08:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: inst panel tailight fuse keeps blowing
Usually a short in tail lights or wiring?
Does it have a trailer plug on it.
Look under side and under rear bumper area and if trailer plug check wiring on it real close.
Also tail light socket or bulb can short out.
Best way to find is to start unplugging until you find short.
They make a short finder meter and also a circuit breaker helps save on fuses when looking for short.
Let us know how it goes.
MT
Old 12-31-2009, 08:47 AM
old_master's Avatar
Advisor/Moderator
If you have an aftermarket radio, check the wiring at the radio. The instrument panel illumination circuit gets its feed from the taillight circuit.
You have to know how it works,
to figure out why it doesn't.
Old 12-31-2009, 09:07 AM
yes it does have a trailer plug
willmcheck wires and rear taillight bulbs
could the headlight switch be at fault?
Old 12-31-2009, 09:45 AM
MT-2500's Avatar
AF - Advisor
Not very often on head light switch.
MT
Old 01-02-2010, 09:41 PM
Smile Re: inst panel tailight fuse keeps blowing
checked out the tail lights and found that a red wire that was connected to the tailights for somereason wwas making contact with the msheet metal of the body ,cut it short and taped it up and problem was fixed .
thanks for all your help Dave
Old 01-03-2010, 10:54 AM
MT-2500's Avatar
AF - Advisor
You are welcome.
Good find.
Sounds like some one had a trailer light wired up to it.
Thanks for posting back how it went and the fix.
Good Liuck
MT
