Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-30-2009, 10:33 PM
r_2016 r_2016 is offline
Exclamation Car squeaking
I noticed yesterday that my TC suspension was making a squeaking sound, when going over a bump. It was very cold yesterday (about 10) and it does not seem to do it when it is warmer out. A few years ago it was making a similar sound and it turned out to be bad outer tie rod ends, they seem fine now tho. Could it have been the extream cold that was causing the noise? Thanks
Old 12-30-2009, 11:26 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Car squeaking
Could have been the extreme cold. It does funny things to metal and lubricants.
If the ball joints are not sealed, you might want to consider using a grease gun and shooting some grease in them. It stopped my squeak back in the summer because the dealer installed non-sealed ball joints instead of the factory sealed ones.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 12-31-2009, 02:40 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: Car squeaking
The coil springs will squeak in the bottom of the spring pockets. Try spraying some WD 40 on the ends of the coils top and bottom. Several of my cars will do it, I know it's annoying.
Mike aka JYD
