Fuel Filter Choice - OEM or Aftermarket?
Should I go with the OEM or look to an aftermarket one? If aftermarket then what brand is suggested?
Re: Fuel Filter Choice - OEM or Aftermarket?
You should change that thing once a year. Try doing it every spring or something so it becomes habit.
I have no opinion on brands, I use fram or whatever else Wally world sells this month. I'd never spend extra $$$ getting one from a dealer. |
FWIW You don't have to go to the dealer to buy an A C Delco fuel filter. Some parts stores carry that line as well as online less than a dealer. For example, Rock Auto.com shows 3 brands of filters for Olds Silhouettes. A Wix brand part # 33183 for $9.94, a FRAM part # G7740 for $12.45, and an A C Delco part # GF819 for $13.78. The Delco is roughly $1.30 more than the FRAM which isn't much if you want to go with the OEM. (They are all decent brand filters and should work with your vehicle.)
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
I ended up going with the NAPA brand. Here in Canada it was $17.00. I figured that was an OK price.
I was also in a rush to get some maintenance done as I was driving to Orlando. Combined with new rear shocks, a oil/filter change, cabin filter change and replacing the thermostat, it was a great ride. Turns out that my thermostat was faulty and wasn't letting the engine get to temperature. It still doesn't get to the middle of the temp. gauge though, about 3/8. I figured I got 26 mpg (US), that converts to 31 mpg (UK). Not too bad for a 10 year old van with 190,000 km on it, loaded with kids/luggage, trecking through the mountains of PA, VI and WV on I77 at 65/70 mph. Also, do I really need to change the fuel filter every year as recommended by merc81? Last edited by SilverOLDS; 02-01-2010 at 01:42 PM. Reason: forgot to add question at end of post |
Yes you really do need to change the fuel filter at least once a year OR every 15,000 miles. I change mine twice a year...every spring and fall. I too use NAPA Gold filters. Changing your fuel filter is just as important as any other maintenance to a vehicle.
"Save water, shower with a friend" |
A partially blocked fuel filter will cause the fuel pump to wear prematurely.
Yearly replacing is just a preventive maintenance project.
The problem with doing nothing is not knowing when you're finished. |
Where is the fuel filter? I thougth they were in the fuel tank..??
The fuel pump and fuel level sender is in the tank.
