Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-29-2009, 08:45 PM
DrRyan84 DrRyan84 is offline
90 Custom Cruiser - Electrical issue?
Hi All:
For years, when I open my driver's or passenger's doors, my radio would shut off - most likely a short or ground somewhere.
Tonight, here in freezing cold Maine, I opened the tailgate to load in some groceries, and tried closing it and it wouldn't close. So I slammed it a few times and it finally closed. However, now the radio display/clock and radio itself is not working - and the light above the rear-facing seats is staying on, even though the tail gate appears to be firmly closed.
Any ideas what's up ? It seems to me that the tailgate really ISN'T closed, even though it seems like it is...since the whole 3 yr history of door open, radio off...but somewhat puzzling. Any ideas?
Does anyone know where the "door closed" sensor is on the tailgate?
Thanks guys!
Old 12-29-2009, 09:02 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 90 Custom Cruiser - Electrical issue?
Imo the first place to look is the door switch on the tailgate. I am not sure what type you have, some have a plunger-style switch, like the side doors, others have a switch inside the door, integral to the latch.
Chances are, the door is closed but the switch has malfunctioned. It is either stuck or has become damaged or distorted, so it is now grounded all the time.
Old 12-30-2009, 12:13 AM
Thanks for your response! I checked - it must be inside the door, no plunger switch at the sidewall.
Would the switch be on the upper or lower latch? I will look more closely at it tomorrow when the temp is above 10 degrees! Any insight into what I am looking for or what the "switch" may appear as externally in the latch?
Also, why is the radio/clock affected specifically by the door switch?
Many thanks.
Old 12-30-2009, 07:36 AM
maxwedge maxwedge is offline
A990 racer
You may have a bad fuse, check the body feed fuse regarding the radio issue.
