Old 12-29-2009, 06:13 PM
labs4ever labs4ever is offline
2000 2 door blazer HVAC/4x4 selector
My blazer has no power to the climate control center or the 4x4 selector system. The blower motor does not work, the duct selector does not work and the 4x4 switch system has no light indicating what position the t-case is in. It does not engage the 4x4 either. Both HVAC fuses in the cab and under the hood are good. The problem started when a wire for added driving lights was run to the fuse panel in the cab and hooked into the HVAC fuse area, the wire became pinched and grounded out causing the problem. Please help, I use this truck to plow snow and I need it! Thanks alot.
Old 12-29-2009, 08:15 PM
old_master's Avatar
Advisor/Moderator
Re: 2000 2 door blazer HVAC/4x4 selector
Did you check both sides of all fuses in both fuse panels with a test light / voltmeter?
You have to know how it works,
to figure out why it doesn't.
Old 12-29-2009, 09:49 PM
I tested each fuse individually in both fuse boxes. I pulled the dash apart looking for a fuseable link also but i cant find one. I also noticed that the gas guage doesnt register now either.
Old 12-30-2009, 11:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
But as Old master said did you check for 12 volts on both side of all fuses to it?
MT
Old 12-30-2009, 05:14 PM
I have found the problem thanks to Old Master. The Orange power feed wire to the fuse block was burned clean through. Bad part is that it was burned in behind the instrument cluster. Tough repair in a tight space but all is well. Thanks again.
Old 12-30-2009, 05:33 PM
old_master's Avatar
Advisor/Moderator
Thanks for posting back with the fix.
