Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-29-2009, 04:26 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Bad MAF someone help
Well my manual transmission car accelerates itself and doesnt stall when in gear any more. It also jumps from 2000 rpms to 2500 rpms when idling....
I figure since I got a new ISC motor it isnt that. I think it is a bad MAF (mass airflow sensor)
anyways can anyone give me a step by step directions guide on how to remove it/clean it up.. Maybe it is just dirty I dont know
like how do I take it apart to clean it (the inside of it of dirt and debree)
it has 140K on the car, visually I DONT see any vacuum leaks, cracked hoses, loose plugs, or cables anywhere...
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 12-31-2009, 01:07 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Bad MAF someone help
Visually is nice, but a leak down test is better. Try checking your IAC before you decide to clean or mess with your MAF sensor.
Always test your parts before you install them, just because theyre new doesnt mean theyre working.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
