Old 12-29-2009, 02:40 PM
4boostin's Avatar
4boostin 4boostin is offline
Nasty rattling/knocking noise, 98 LSS
I know that this is a Grand prix forum, but i figured i'd get some good help here, not too many supercharged oldsmobiles.
My supercharged LSS is making a scary knocking noise at and below 1100 rpms, it gets worse when i put it in gear and just sit there with the brake on. I've removed both belts and tested all the pulleys, they're all solid. But when we try to turn the motor a bit manually by spinning the either belt while attached, the main crank pulley only goes so far in either direction, clockwise or counter, and clanks to a stop, making a similar noise to the one it makes while running. (We took the main belt off and turned the motor a bit with the other attached, and also with did the same removing the supercharger belt.) Note that the noise fades out quick as the rpms raise in gear or not. Could this be my harmonic balancer? And if so, what does that entail to fix it/replace it?
Old 12-29-2009, 04:45 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Nasty rattling/knocking noise, 98 LSS
that was my thought while reading your description. while removing the balancer, you have to ensure the motor will not turn over. I put a small pry bar in the flywheel to keep it from turning over. you can do so by removing the inspection cover located by the starter. you will also need to purchase a puller to remove the harmonic balancer. they can be purchased fairly cheap at most automotive stores.
Old 12-29-2009, 05:14 PM
CrazyHorst CrazyHorst is offline
I made up this tool to restrain the crank from the pulley end while the balancer bolt is removed or installed. Advantage is that you can probably work alone but will need access to holesaws/drill presses and a welder and some time to make it up first.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 12-30-2009, 04:17 AM
Oh yes...while you are in there I would strongly recommend changing the crank sensor if you haven't done so yet.
2009 G8 - GT (46k)
Old 12-30-2009, 05:33 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
try running it with the belt off and see if the noise changes.
I'm also leaning towards a bad balancer.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
