Old 12-29-2009, 04:37 AM
kaho's Avatar
kaho kaho is offline
polish debris in panel lines
Whenever I finish polishing a car body with sandpaper and polish I always end up with debris stuck inside the panel line gaps. These include some clearcoat off the orange peel that has been sanded flat and most polishing compounds, which turn white as they dry. My old way of getting rid of them was to run a corner of paper through the panels lines but often it is impossible to get them out this way. On white cars it seems fine that I don't clean out all of them but on darker colored cars the white debris stand out like a sore thumb and even with the black paint wash they often resurface after the black dries. Soaking the body into water/hand soap mix didnt work. I had been contemplating soaking the body in more aggressive cleaners like dish detergent or windex, but although I am using 2K clearcoat (which I think should be fine soaked in most liquids except brake fluid), I am afraid even a mild detergent may attack the styrene underneath.
Can anyone give me some ideas of cleaning the polish/sanding clearcoat debris out of panel lines efficiently?
Old 12-29-2009, 04:44 AM
klutz_100's Avatar
Re: polish debris in panel lines
Presumably they are clean before you lay the clear coat?
I have always found that a toothpick carved to a flat, bevelled chisel shape more than effective at getting gunge - usually wax deposit - out of panel lines (but I guess you have already tried that?)
Old 12-29-2009, 07:52 AM
tonioseven's Avatar
I use a soft-bristled toothbrush to gently coerce the debris from the panel lines. Doing this under running water helps.
sam-r350 UP.Browser/6.2.3.8 (GUI) MMP/2.0
Old 12-29-2009, 08:48 AM
The Yes Man's Avatar
The Yes Man The Yes Man is offline
I do exactly the same with the toothpick, i also wet the end slightly.
Old 12-29-2009, 11:40 AM
stevenoble's Avatar
Use a toothbrush or toothpick and detergent. You won't harm 2K clear with dish washing detergent, it won't even touch it.
Steve Noble
Old 12-29-2009, 12:22 PM
kaho's Avatar
I am pretty positive that the body was clean before the clear coat was applied; there were no residue to be seen after the painting and clearcoat step in panel lines.
I will try the detergent today.
Old 12-29-2009, 12:52 PM
Veyron's Avatar
Veyron Veyron is offline
I use a toothbrush made for babies.
I put the body in a bowl of soapy water for a minute then gently scrub the panel lines. Run hot water over the brush to soften the bristles even more if they feel too stiff.
If the brush leaves any marks in your paint...get better paint.
Old 12-29-2009, 08:32 PM
kaho's Avatar
ok toothbrush for babies...um I didn't know these existed, I just knew there are different sizes and softness, I will go take a look.
Nope my old hard bristle toothbrush did not scratch the clearcoat even with moderately high force. However such thing did happen back when I was using tamiya TS13!
Old 12-29-2009, 08:53 PM
rallymaster's Avatar
There might be another possibility if you're afraid to give your paint a too agressive treatment with toothbrush.
I use a coton earstick slighty wet applied in all panel lines, grilles etc after having polished my bodies and parts.
That may be a solution too.
Phil
Old 12-29-2009, 11:35 PM
Entau's Avatar
Entau Entau is offline
i use those very small dental brush to clean compound left on the panel lines, soap & bubbles make it easier to be remove
