Old 12-28-2009, 09:55 PM
Firstymer Firstymer is offline
Exclamation Emergency: Car shut off while driving!
My 00' GP SE 3.1L w/ 127600+ km continues to shut off on me while driving whenever I fuel up to a full tank, half or putting gas period it starts to idle real bad i.e. RPM gauge goes from 0-4 repeatedly when I turn the car on. Then when I drive off it will shut off. Im not a expert but Im assume it gotta be the fuel pump since there is excess pressure in the line.
Likewise, while driving on the expressway for about 7 hrs I notice the car will make a noise as if the acceleration is jammed. I tried to give it some more gas but the gauge reads at 70 mph remain until I take my foot off the gas padel and then apply it again!
Old 12-28-2009, 10:46 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Emergency: Car shut off while driving!
Like you said, I would check fuel pressure first.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-29-2009, 06:56 PM
What is the procedure to check the fuel pressure?
Old 12-29-2009, 07:02 PM
danielsatur danielsatur is offline
Don't forget about the fuel filter too!
Old 12-30-2009, 09:45 AM
daejuanj daejuanj is offline
Send a message via ICQ to daejuanj Send a message via AIM to daejuanj Send a message via MSN to daejuanj Send a message via Yahoo to daejuanj
Not sure the specifics, but two years ago when my car would stall and idle rough it turned out to be a defective MAF sensor. No SES light or any other indicators.
- 2002 Pontiac Grand Prix GTP (81K miles)
Magnaflow High-Flow Cat, U-Bend & Resonator delete
Got3800 Race Day!
Old 12-30-2009, 01:39 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
there is a schrader valve on the fuel rail that you hook a fuel pressure guage to in order to test fuel pressure. Key on/engine off pressure should be 48-55psi and should drop 3-7 psi with the engine started. If you pull the vacuum line off the fuel pressure regulator with the car running, fuel pressure shoul spike back up to near key on/engine off spec.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-31-2009, 04:47 PM
Nope! no SES light or any indicators. But I can say when the car shuts off on me the steering wheel becomes stiff or hard to turn and the check engine light and everything else comes on. Im thinking about taking it to the dealer to check it out
Old 12-31-2009, 06:17 PM
GTP Version 2.0 GTP Version 2.0 is offline
Did you check the TPS? Does the car have problems shifting at all? When you unplug the MAF does the car drive ok? It might be the fuel pump. Try the fuel pump resistor switch trick.
Old 12-31-2009, 06:30 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
the 3100 and NA 3800 dont have fuel pump resistors
i wouldnt bring it to the dealer. i would be willing to bet it is a bad fuel pump. it really isnt that hard to change...especially in the 97-03 GP since theres an access door, so you dont need to drop the tank
Old 01-01-2010, 08:51 AM
Oops, didn't read his application.
Old 01-01-2010, 08:42 PM
Thumbs up Re: Emergency: Car shut off while driving!
Thanks for the support. I would probably change the fuel pump since from the looks of it from the underbody the fuel tank has a dent in it. I will try to post a pic of the damage tank over the weekend to provide some aide. Is there any steps or procedure on how to change the fuel pump since you don't have to drop the tank??
Old 01-01-2010, 11:08 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Help yourself to avoid delays or waiting for a reply by visiting our Grand Prix Tips & Maintenance forum which has a detailed tech procedure on replacement of the fuel pump assembly. See link below.
Click here
Timeslip 08/12/06
AF Community Guidelines
