Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-28-2009, 07:48 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
possible trans issue
Whenever i'm around half throttle when it shifts into third gear you can feel some vibration for a second until it gets into gear. Its almost like when you drift into the breakdown lane onto those bumps in the road, except to a lesser extent. Its only noticeable every so often too. Like i've mentioned before ive had the trans rebuilt/refurbished so that it shifts "quicker". I'm not exactly sure what the guy did but i hope he didnt mess something up
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 12-29-2009, 09:21 AM
j cAT j cAT is offline
Re: possible trans issue
that could be the tranny slipping...what fluid did you/he use... ?
this may also mean the pressure is low. it is possible that this is in need of measuring..
Old 12-30-2009, 07:35 AM
iroc343 iroc343 is offline
If I remember correctly these cars had issues with the lock-up converters and sometimes changing the fluid and filter would eliminate the shudder.
