Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-28-2009, 08:03 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Bumper Filler: Rubber vs. Fiberglass
Hey guys,
I'm looking to get a new front bumper filler for my '87 wagon. I've been looking at the product from replica plastics http://www.replica-plastics.com/Edit...Make=Chevrolet and called them and they told me that their fillers are fiberglass. Is there any disadvantage/advantage to using a fiberglass filler over a rubber filler?
Thanks,
Alex
Old 12-28-2009, 08:10 PM
danielsatur danielsatur is offline
Re: Bumper Filler: Rubber vs. Fiberglass
Check your local salvage yard, you might beable to find one the same color.
Old 12-28-2009, 08:30 PM
Thanks but that doesn't really answer my question at all haha. I already called most of the salvage yards in my area and none of them have caprices, so it looks like I have to buy new here.
Does anyone have an opinion on the choice between a rubber and fiberglass filler?
Old 12-28-2009, 09:53 PM
CD Smalley CD Smalley is offline
Fiberglass will be stiffer. So if you hit something, it will break vs. bend.
The rubber will be harder to paint as it has to flex. But there are additives for the paint to allow this....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 12-28-2009, 10:45 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
I need to replace my front filler also.
It looks like it is still available from GM.
The following link shows it is still available.
I would guess the OEM part is urethane not fiberglass.
The urethane part would have some flex and not crack like fiberglass would if bumped.
http://www.gmpartsdepartment.com/par...layCatalogid=0
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 12-29-2009, 01:45 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Correct, the OEM part is urethane which as old as it is, tends to start cracking and falling apart. The fiberglass part will last longer (as far as rot is concerned) but is more fragile and less forgiving. The new GM part above is the best bet as it is OEM.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
