Old 12-28-2009, 02:40 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Part Number for Bottom Bumper Guard
So, Just my luck. Driving to work today I was following a semi, Not sure if the big mound of snow fell from the bottom of the semi or if the semi hit it before I did. Either way, I couldn't stop in time or swerve around it. I hit it pretty much straight on. I think it was solid ice because it hit hard and smashed up the bottom black strip of plastic under my bumper. I have not had a chance to check closely to see if my bumper was cracked, but it appears to be ok. The curb guard plastic piece on it though is toast as half is missing. Anyone know the part number for this?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-28-2009, 05:44 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Part Number for Bottom Bumper Guard
Tim. the part is called a Deflector, Lower Air or Radiator Air Deflector/Baffle. The GM PN used to be 10423208 but may have been revised to a new part number so check with Rich to be sure. But the number appears to be good and the GM list price is $64.61.
Timeslip 08/12/06
AF Community Guidelines
Old 12-28-2009, 07:47 PM
tblake's Avatar
In God We Trust
Thanks Bob, I appreciate the help.
Any word on how to replace it? I only had a chance to glance at at, but it appears part of it is under the bumper, and I think I might have to take the bumper cover off to get it out.
Does that sound right or am I seeing things?
I've still got my fingers crossed on the bumper cover itself. I'm hoping I dont have a big crack hidden by salt and dirt. The impact somehow made the passenger foglamp go out too, Whether the wiring is bad or filimant just broke apart I dont know yet.
I think I will spray the car down and see what I have.
Old 12-28-2009, 08:10 PM
doctorhrdware doctorhrdware is offline
When I pulled mine off, it had the black like push pins.
Old 12-29-2009, 09:39 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Tim, Bob is correct on his part number and list/retail price, as there is no updated part number. It appears to mount with three bolts (m6x1.0x16mm) in the center and 2 push-pin type fasteners on the outer edges
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-29-2009, 10:11 AM
tblake's Avatar
In God We Trust
Sounds good, Thanks guys!
I just hope when I go to remove it that I dont snap those bolts off. As usually ones that low on the car in MN are usually rusted solid to the frame.....
