Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-28-2009, 11:37 AM
headscratching headscratching is offline
Brake Grinding
I have unfortunately driven my saturn sl2 to the point that my front brakes are grinding at low speeds, not screeching from the worn pad sensors but grinding, i know I need new pads and most likely rotors, bot of which i can replace, but I am concerned that the grinding noise is the result of the caliper piston on the rotor...Do you think I am going to need new calipers? Have I damaged more than the rotors? I have only been driving under these conditions for about a week, and only short drives.
Old 12-28-2009, 01:02 PM
inafogg inafogg is offline
Re: Brake Grinding
as long as they are worn evenly & piston push back fairly easy you should be ok
just lube the slides when you do repairs,Good Luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 12-28-2009, 01:10 PM
Re: Brake Grinding
by lube sides do you mean the sides of the piston before I push it back...I guess i am kinda foggy as to what I should lube when I replace pads and rotors
Old 12-28-2009, 04:34 PM
Cat Fuzz Cat Fuzz is offline
Re: Brake Grinding
The calipers slide on pins. Make sure they are clean of gummy grease and re-lubed.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 12-29-2009, 10:52 AM
RC1488 RC1488 is offline
Re: Brake Grinding
re-lubed with caliper grease. Not normal grease as it will burn off.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
