| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
hello everyone
![]() sorry but i am a newbie and about to start a Revell 1/24 audi r8, so which (tamiya TS paint preferably) would i use if i wanted to replicate this type of black colour shown in this picture? ![]() http://cars.uk.msn.com/features/phot...182692&page=10 thank you!!
Re: which paint for this look?
Which picture of which car? There are a few on there.
If it's the black Lambo you're talking about the colour is called Nero Pegaso and you can get it from Hiroboy's Zero range of colours.
Niclas |
If not I would suggest just using Tamiya TS-14 gloss black straight form the spray can. If you apply it slowly and carefully with a moderate final wet coat, there may well be no real need to put a clear coat on it or even polish it to achieve a nice gloss finish. Check out Alex Kustov's tutorial for painting - A very good guide to basic techniques and processes http://italianhorses.net/Tutorials/P...aint/paint.htm
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
thank you for replies.
![]() yes i am talking about the blalck lamborghini on there. the colour on it looks perfect. ![]() i dont have an airbrush so cant really use zero paints, i tried to see if i could buy one but they are too expensive at around 50-70 GBP for a good dual-action one. ok i was wondering if any of the tamiya black sprays with a clearcoat would produce that kind of result, ofcourse it would require really really good painting technique to get it just like that. so i will try TS-14 black, i have to order over internet and dont really have a hobby shop nearby where i live. |
DSheth the paint is important, but take time to body work first. You have to wash the body to remove grease and demolding agent, sand all the body to remove any imperfection and all the injection marks - fine lines that cross the body, fill the gaps and little holes with Tamiya Putty or similar, sand it again and wash to apply an or two coatings of primer, sand again, this will help you to verify if everything is flat and uniform. I like to deepen the panel lines with the scriber to real looks. You have to polish for the shine looks. Good luck!
Almeida... I'm back! |
thank you AAlmeida
im gonna buy the TS black along with tamiya fine gray surface primer, i heard that grey primer works for darker colors and white for brighter colors, and that the primer has to be even throughout otherwise the base paint coat wont come out deep looking. another question i have is that on tamiya website it says its best to paint the parts while they are still in there trees, but dont you have to apply primer to these parts aswell so it would be best to cut them out and prime them together in sets that you'll be using? |
Until somebody invents an anti-gravity machine, it's impossible to float parts in mid-air for painting. So in most cases you'll need to paint the part twice to completely cover it. As for painting the body, I know of two ways to get that extremely deep, glossy black. You're on the right track as far as primer is concerned. Tamiya Grey will work fine for you. If you don't want to buy an airbrush, use Tamiya TS-Series glossy black and clear-coat it with Tamiya TS-13. Even better - and a lot cheaper - clear-coat with U-POL Power Can clear. In the U.S., you can get it from Sam Ditchek & Sons at http://yhst-13811118617756.stores.ya...uppocanae.html It's made in the U.K. (Wellingborough, Northants, England) so you should be able to get it at auto supply stores there. After you've clear-coated, lightly wet-sand the body with 2000 grit to remove all orange peel and paint texture. (If you burn through to the color coat - s__t happens! - re-clear the area. TS-13 and U-POL will blend nicely with the previous coat.) Then follow the Tamiya compounding sequence: Coarse, Fine, and Finish. Finish is very, very fine compound and will produce an incredible gloss. You can also wax the car, but I think Tamiya Finish renders waxing unnecessary. The Tamiya system is pretty much foolproof. Warm the spray cans under the hot water tap before spraying. Hold the nozzle about seven inches from the piece and move it fast to avoid sags and runs. You don't need to sand between coats. Humidity is not a big factor with lacquers; drying times are short, so dust is not a major problem. Just be sure to wait a few days before final sanding and compounding. But even Tamiya TS and Tamiya Finish won't give you a gloss as awesome as 2k automotive urethane clear-coat. That's where Zero paints come in. But you'll need an airbrush. Follow their instructions and you'll get amazing results. (I do have a concern about 2k clear-coats, especially for beginning modelers. They are virtually impossible to strip. If you screw up, you might as well trash the model.) Ddms Last edited by Didymus; 12-28-2009 at 05:16 PM. |
wow thanks alot for all that and i will definately try the U-POL clear coat
![]() i wont be able to use an airbrush to clearcoat because it would also mean i would get a compressor which is even more expensive. ![]() and did you mean TS-14 black like the other guy mentioned or TS-29 semi-gloss black? |
Please let us know how it goes. That's a pretty reasonable price for all this advice! Ddms |
Hi,
I noticed your location is in London and as far as I'm aware, there still aren't any Tamiya spray cans available in the shops. It might be worth your while going into your local Halfords for their range of paints as it might end up being more economical for you. They also have clear coats in spraycans too. Also for your information, TS-14 has a glossy finish and TS-29 has, as it's name suggests, a semi-gloss finish which would be incorrect for the finish you appear to be after. Best of luck.
From reading Halfords' instructions, I get the impression that their spray paint is a synthetic lacquer like Tamiya TS-series and U-POL. Just follow the same procedure that we've suggested.
If you can't get the Tamiya compounds at local hobby shops, it's worth it to order them on-line. It's pricey stuff, but the tubes are light and compact, so shipping should be cheap. |
I recommend that you DON'T use TS13 on your first model. There is a strong possibility/probability that you will lay too thick a coat and it will probably dissolve your paint and you won;t be happy. TS13 is a virulent clear coat - just do a search here on AF - that has led to many tears and frustrations.
I suggest that you get some Gunze Mr TopCoat and use that. It gives just as good a finish and is won't damage the lower layers (or decals). TS13 can give great results but is best used with some previous experience IMHO As I said above, if you take it easy and prep well for the TS Black, you probably won't need a clear coat any way. It's better to set realistic goals for your first builds to avoid frustration. Focus at first on good preparation, a clean building style, laying paint well.
You also don't need to clear over tamiya's gloss colour paints out of the can.
For reference, none of the plain colours i.e non-metallics (er... that'll be the black and red ones) in my sig have been clear coated.
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
