Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-27-2009, 12:37 AM
allen405 allen405 is offline
tranny install
I pulled the tranny and it proved to be quite a treat but I am having one heck of a time trying to get the used one back in. Does anyone have any helpful advice to help get it back in
thanks in advance
Old 12-27-2009, 02:01 PM
Jrs3800 Jrs3800 is offline
Re: tranny install
I used my floor Jack with a board of wood 8" wide and 16 " or so long... I tried to get the trans as level and as balanced as possible..
Once it hits the pins a little nudge to make sure and then thread a couple of bolts... It is difficult to put the trans back into the van...
I wish I had a Pic for you...
Old 12-27-2009, 02:09 PM
danielsatur danielsatur is offline
Re: tranny install
Use a piece of wood & jack up the frnt of the engine!
The rear of engine will tilt down for easy installation.
Old 12-29-2009, 10:32 AM
Re: tranny install
Actually if you are using a trans or floor jack to install the trans this will make it worse... and if you do not support the engine close to level you'll bend the bracket to dogbone mount and damage the front motor mount under the oil pan.... I do not recommend jacking on the front of the engine at all..
