rear axle bearing and seal replacement
Hi,
97 GMC K1500 XCab with the factory locker diff. I'm fairly certain that a rear wheel bearing is starting to go. I know there are c-locks inside the diff on the axles, but the shop manual says "Use GM tool /n xxxx to pull the seal then xxxx to pull the bearing out of the axle housing. Are these GM pullers absolutely necessary?![]() I will probably start the job to see how it looks in there. Thanks for help and advice, Bob B |
Re: rear axle bearing and seal replacement
You can pop the seal out with the end of the axle, a pry bar, or a screwdriver. The bearing is a lot easier with a slide hammer and a bearing remover. The new bearing can be installed with a seal/race driver.
Bob B |
If you have a long metal rod/pipe you can push them out by sliding the rod/pipe in at one side to push out the other side. Just be sure to keep the carrier shims in the correct location (side).
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck) 1968 Pontiac Parisienne (rust free survivor) 1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck) 1989 Chevrolet K3500 RC/LB (454 & single rear wheels) 1991 Chevrolet Caprice Classic (police cruiser clone) 1992 Chevrolet K2500 EC/SB (almost rust free daily driver) 1998 GMC C1500 EC/SB |
seal comes a out easy and as us southern boys like to do we like to cut stuff up ha ha so i found best to take a cuttin torch and split the bearing in 2 halves and out comes the bearing! Just be careful not to cut your rear housing in 2 halves
