Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-25-2009, 09:01 PM
GTS767 GTS767 is offline
Cleaner for Engine and frame Rust Parts
Just bought 03 camry, and found that the battery liquid somehow contaminated the area underneath the battery at some time in the past. This included some of the frame, painted area of the inner fender and transmission housing. I plan to clean the painted surfaces with soap and water since it seems like surface rust, but the transmission housing is hard to do, so I may sand it with sand paper to the best I can. Even though I sand it down, rust is still deep down in small pores. Any recommendation for a rust cleaner and rust protection that I should use after cleaning.
Would appreciate
Old 12-26-2009, 10:42 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Cleaner for Engine and frame Rust Parts
I used Rustoleum rusty metal primer followed by some Rustoleum paint, when something similar happened to my 86 Camry years ago. I would still sand off as much rust as possible first, as you said you were going to do.
Mike
Old 12-28-2009, 10:14 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
First neutralize the acid by pouring a mixture of baking soda and water. Keep dousing it until it doesn't fizz anymore. Then rinse with water.
I'll also suggest the use of RustOleum's Rust Converter prior to the primer for any rust that can't be reached.
If you can remove the battery tray to prep and paint it (it's probably just as bad underneath as it is on top) then you'll have better access to the damaged paint underneath. I like the 3M Paint and Rust remover wheel in a power drill for large areas of mostly surface rust with some pitting. A coarse 3M scouring pad for harder to reach areas. Unless there's oil or grease contamination of the area, I wouldn't use soap, just clean water and air dry...compressed air quickens the drying time. Any left over rust gets a shot of converter then primer and color coat. Since it is inside the fender, you don't need a clearcoat Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
