Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 12-25-2009, 12:16 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Air/Fuel Gauge Hookup...
With the oxygen sencor, which wire would i want to hook the air/fuel ratio gauge wire up to for it to read correctly? i believe there are 2 green, white, gray but im not positive... does snyone know which wire i would splice into or should i just go straight for an ecu hookup?
If you also had any suggestions for which vacuume line to tap a vacuume gauge into that would be helpful also... i was thinking the one off the throttle body because the hose is a bit worn and needs to be replaced... would that be a good choice?
thanks for any input, have a good xmas.
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 12-25-2009, 02:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Air/Fuel Gauge Hookup...
Tap into your 02 sensor wire at the ECU. 2gnt has ECU pinouts for the ecu so check those out and that will tell you where the wire is. For the vac gauge anything on the intake manifold should work. You should be pulling 17-19 in.hg at idle so as long as your getting that you will be fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-25-2009, 05:44 PM
sounds good thanks
Under The Hood:
Interior:
