Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-26-2001, 07:30 PM
twofingersj twofingersj is offline
Stalling Primera
Hi all,
I am a Nissan Freak from Jamaica, and I own a Primera and a GTS-4 Skyline, I have a problem with the Primera (Infinity G20) though, it is a 1996 Automatic model powered by the SR20DE, occasionally in traffic in Drive with the car moving at idle, when I get on the gas the car stumbles and sometimes stalls.
When performing the Diagnostics i get a code 43 which is the throttle poeition sensor. what do you guys think. also how much power can the automatic transmission handle as I am planning to add a turbo (Garrett t28 or T3) and run around 6 lbs of boost.
Later
The redline is there for a purpose, and it should be used.
Old 10-26-2001, 08:01 PM
T4 Primera T4 Primera is offline
Go have a look at this link for tuning/troubleshooting:
http://www.se-r.net/car_info/problems/index.html
Use the forum search facility for the auto/turbo thing. I recall it has been discussed before.
Welcome to AF, have a good read.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 10-27-2001, 11:44 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
check out diz web site
http://home.talkcity.com/gasolineal...renan/Front.htm
94 G20t
Old 10-29-2001, 09:05 PM
AWD Primera's Avatar
AWD Primera AWD Primera is offline
Re: Stalling Primera
Originally posted by twofingersj
Hi all,
When performing the Diagnostics i get a code 43 ...
Can someone explain to me what is diagnostics? - Can you plug something into your Primera in the plug below the fuses that does diagnostics on your car - Im guessing? If so, anyone know where to get one of these. If not - explain?
Old 10-30-2001, 01:25 AM
Re: Re: Stalling Primera
It is possible, by shorting out a couple of pins (IGN and CHK) on the diagnostic connector, to place the ecu in diagnostic mode where it will flash any trouble codes recorded in the ECU memory using the check engine light. If you have a check engine light lit or flashing, this could help narrow down the problem, if not - then there probably isn't any reason to do it.
This is different from the diagnostics that the dealerships do using a special diagnostic computer (Consult I think they call it) which can collect more info such as voltage/current readings into and out of the ECU. Probably too expensive to purchase for personal use, although if you get one you'll be very popular ...
-- Bertrand Russell
2005 stalls and stalls and stalls... MN Ding Dong Focus | C Max 3 06-27-2011 07:52 PM
Stalls when revved to over 3K rpm jkoch53102 MPV 2 12-19-2010 08:14 PM
Another stalling problem (95 GS) Cmal Regal 3 12-12-2009 02:41 PM
2000 2.4 Stalling Issues SteveFord26 Cavalier Problem Diagnosis 7 09-11-2009 08:56 AM
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 07:23 PM
