No Driver side heat: HVAC climate control
My daughter's 97 GS Regal recently stopped blowing warm air on the driver's side. Air flow is good but the air was COLD. Passenger side works fine.
Based on other posts on this forum, I turned the HVAC control to OFF manually. Then I removed the negative terminal connection on the battery for about 30 minutes (Reseting the climate control). I put the connection back on the battery and started the engine. The climate control now works FINE. Heat on driver's side!!!! Thanks to Bob Naylor.
This site rocks!!!!! I tell everyone at work to check automotiveforums when they have a car problem.
