Old 04-10-2003, 06:19 AM
tuari1 tuari1 is offline
Send a message via Yahoo to tuari1
Unhappy 1997 V-6 Vortec won't run! HELP!!!
Ok. Thanx-I got it running.Seems the Fuel Injector Reg was missing. But now it skips. Ive checked time and done comp check.If I loosen the dist holdown the distributor wobbles profusely. Put new plugs,cap, and rotor on it. Guess I'll try pulling dist to see if the pickup coil is damaged. Thanx alot for the replies...
Scott
Thanx a bunch!!
Old 04-11-2003, 10:37 PM
cobra1 cobra1 is offline
first go back and double/triple check your connections. also check that you didnt damage the MAF sensor. it has a couple very fine filaments, and if these are damaged, it has to be replaced.
also, you say NEW engine, is newly rebuilt, or from a salvage yard?
as much info as you can provide will greatly increase chances of someone sending you in the right direction.
2002 Cavalier starts, won't run...Help? Sirenmedea Cavalier Problem Diagnosis 0 11-28-2005 12:40 PM
99GS won't run help!!!!! vjp64 Regal 11 04-26-2005 08:40 AM
82 camaro won't run, help please twiggyacb Camaro Discussions 6 03-03-2005 12:46 PM
1986 2.8l V6 won't run--HELP! Sam Thomas Cherokee 7 09-28-2004 05:05 AM
