Old 12-23-2009, 03:42 PM
ColoradoSilverado ColoradoSilverado is offline
Electric motor noise?
I have this noise that sounds like a electric motor running, at first I thought it was the ABS pump but it's not. I hear it with the engine running while driving or standing still, sometimes it goes off for a while but it's on like 90% of the time. I crawled under the truck and it almost sounds like it's coming from the transfer case. Any thoughts?
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 12-23-2009, 04:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Electric motor noise?
Does 4W shift from 2W to 4W and back?
If noise from transfer case unplug it and see if noise quits.
And feel ABS motor for motor runnning.
MT
Old 12-23-2009, 06:04 PM
4WD selector works fine (drove thru the snow today and shifted from Auto 4WD to 4WD several times). ABS pump I unplugged (both electrical connectors) and it still makes the noise. I also unplugged the plug to the transfer case which also made no difference.
Bert
My Truck:
My wife's Truck:
Old 12-24-2009, 08:35 AM
MT-2500's Avatar
AF - Advisor
Bert
Noise sometimes travels .
Go over everything and see if you can feel or hear where it is coming from.
Sometimes a long steel bar or pipe or listening device helps find it.
Also sometimes fuel pump can make extra noise.
Good Luck
MT
Old 12-24-2009, 10:03 AM
mustanger999 mustanger999 is offline
Your power steering pump could be the source for the noise. If fluid is too low or if pump is going out it can make a whining noise much like an electric motor. Does the noise increase when you turn the steering wheel?
Old 12-24-2009, 10:23 AM
I will definitely let you guys know what I find but it's gonna have to wait a few days, it's to cold and too much snow right now.
Bert
My Truck:
My wife's Truck:
Old 02-05-2010, 06:54 AM
Well, still haven't been able to figure out what the noise is, it's definatly coming from the transfer case, weird thing is that it always sounds the same, standing still idling or driving down the road, switching between 2WD, 4WD and AWD doesn't make any difference, sometimes it will stop for a few seconds and then it's back again. Any thoughts?
Bert
My Truck:
My wife's Truck:
Old 02-05-2010, 08:10 AM
MT-2500's Avatar
AF - Advisor
Unplug the transfer case shift motor and see if noise leaves.
Also sometimes ABS brake motors make same noise.
MT
Old 02-06-2010, 10:22 AM
Forgot to mention, noise is only when engine is warmed up. Will try the transfer case plug later today when it's a little warmer outside.
Bert
My Truck:
My wife's Truck:
Old 02-18-2010, 04:35 PM
semisendiz semisendiz is offline
Well, here is something for you, but this WAS my noise: Radio has a cooling fan, starts on and off, when truck warms, pull it out radio (or just disconnect when sound comes on) to see if this is it. It was in mine.
Good luck.
Old 02-18-2010, 09:34 PM
This is what I eliminated so far: ABS pump, Power Steering Pump and Transfer case.
Bert
My Truck:
My wife's Truck:
