Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 12-23-2009, 01:13 PM
sherman22 sherman22 is offline
94 bravada sputtering.
have 94 olds bravada. just replaced fuel pump and filter. fired right up ran until got warm then started sputtering. let set over night got in it started right up. drove around once warmed up started sputtering again. any advice?
Old 12-23-2009, 06:50 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 94 bravada sputtering.
Is the Check Engine light on?
Old 01-03-2010, 07:33 PM
beatdr beatdr is offline
egr valve? I have to clean mine all the time or it runs funny.
Old 01-04-2010, 01:55 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
get a screened gasket
Old 01-04-2010, 09:02 PM
AF - Advisor
When an ignition coil starts going bad, the engine will run good cold until it gets to normal operating temperatures then as the ignition coil warms up, the engine will start misfiring.
Old 01-30-2010, 04:23 AM
silverhair silverhair is offline
Just went through something similar, changed fuel filter, no better, put on new coil to no avail, finally had to take it into a shop, they ended up replacing the distributor, cured the problem, in fact it has not run better for several years, seems like it very slowly deteriorated over time and it was not really noticeable until it started failing badly. Am really delighted at how smooth it is a idle and more power at speed now......
Old 01-31-2010, 07:13 PM
AF - Advisor
Thanks for the info and welcome to the site Silverhair!
Old 03-09-2010, 11:19 PM
bhart2489 bhart2489 is offline
i also had the same prob. i took it up the the shop and the air intake is what caused it, don't ask me how it just did, one of the clamps came undone and the tube fell out just enuf to mess with the mass air i guess. the shop charged me nothing so i dont think they lied to me
