Old 12-23-2009, 11:26 AM
tacmale tacmale is offline
Transfer Case
I have searched and searched for this answer and can not seen to find it anywhere. I have a 93 S10 blazer 4WD, 5 speed manual tranny. And the transfer case makes a noise like the chain is slipping if I have to make a start on a hill. The front wheels will also spin on gravel with a quick start from a dead stop.
I am thinking of replacing this transfer case as I have replaced both switches, the one on the front differential and the one on the transfer case as well but still seem to have the problem.
The answer I need is are the splines the same for a transfer case from an automatic or a manual transmission. Or do I need to find one from a manual transmission. This is not an electric shift transfer case but a manual shift one.
Old 12-23-2009, 05:58 PM
old_master's Avatar
Advisor/Moderator
Re: Transfer Case
Probably the same, but check with a boneyard to be sure. They will be able to tell you for sure.
You have to know how it works,
to figure out why it doesn't.
