Old 12-23-2009, 09:28 AM
llerrad llerrad is offline
O2 sensor after the muffler
1999 Cav. check eng. light on, code calls up O2 sensor after the muffler, replaced it light came back on replaced it again and light came back on. is there something else that can cause this code? or am I down to putting black tape on the dash over the eng. light.
Old 12-23-2009, 10:44 AM
mustanger999 mustanger999 is offline
Re: O2 sensor after the muffler
Maybe sensor is not bad, but telling the truth?
Old 12-23-2009, 08:48 PM
J-Ri's Avatar
J-Ri J-Ri is offline
What code was it exactly? The post-catalytic converter (not muffler ) O2 sensor monitors the cat efficiency. If your code was p0420 (cat. efficiency below threshold), then most likely you have a bad cat. If that's it, you should still check the upstream O2, if it's reading lean and the PCM is commanding rich, then the post-cat O2 may be seeing that extra fuel and "thinking" the cat's bad. The PCM basically just compares the two to see how the cat's doing.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
