Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-23-2009, 07:30 AM   #1
LEM
90 LX 5.0L No/Low Hot Air and Radio Display Issue
With the colder weather arriving I've had to use my defroster more and more. However, even well after the engine has warmed up I'm not getting much warm air out of the heater whether I have it on defrost, vent, floor, or mix. The engine coolant level is good, I just topped it off a couple of weks ago. What could cause this and how do I fix it?
Also, the stock radio hasn't had a display for the last few years. The green LEDs don't shine. Any fixes for this?
Thanks much and Merry Christmas!
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
LEM is offline   Reply With Quote
Old 12-25-2009, 03:05 AM   #2
fordtrucksonly
fordtrucksonly's Avatar
Re: 90 LX 5.0L No/Low Hot Air and Radio Display Issue
Make sure your selector valve (Control head) dosen't have a vacuum leak causing it to not blow defrost. Normally they will not blow anything else but defrost, but it can do the opposite. As far as the radio goes, just replace it. If you can get me a picture of the radio I might have one laying around I can get to you.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
fordtrucksonly is offline   Reply With Quote
Old 01-04-2010, 10:27 AM   #3
LEM
I should also mention that my cruise control doesn't work anymore; could this also indicate a vacuum problem? Where do I begin to look for a leak in the vacuum system?
Thanks.
Old 01-04-2010, 09:47 PM   #4
fordtrucksonly
Thanks.
You can air/smoke test the lines or an easier solution, Take a can of brake clean and spray the vacuum lines until you hear a sound change.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 01-07-2010, 08:36 AM   #5
LEM
Okay, I need a little more info on the brake cleaner test of the vacuum lines: where do I spray it? What kind of change in sound should I listen for?
I checked the "temperature door" (the damper controlled by the temperature knob though a cable) and it is moving okay. When I have the fan on the slowest speed I do get some warm air through the vent and the floor - I need to double check to see if I get it through the defroster as well, but let's assume I do. When I increase the fan speed I lose the warmth and it seems to be blowing ambient air no matter what I have it set on (floor, vent, mix, defrost).
The fluid level is good. My engine temperature gauge reads normal, so I don't think it's the thermostat, though I plan on checking it tomorrow.
How can I troubleshoot the selector knob to see if it's working properly?
Is there a fluid valve somewhere in the heating system that could be stuck? Does anyone have a piping schematic for the heating system?
Thanks for the help.
Old 01-07-2010, 08:43 AM   #6
fordtrucksonly
You should be able to hear the vacuum, kind of a whooshing sound, when you spray the lines with brake clean, once you hit the spot of the leak the pitch of that sound will change.
'95 Ford F-150
Ford Racing Pride
General Motors who?
