Old 12-22-2009, 11:16 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
New turbo from the junkyard
So you all know the 20g got damaged by the compressor nut so I was in the market for a new turbo. The 20g would still boost but spooled slower, had a few chipped blades and the shaft got a little bent. I wanted a turbo that was a little bigger than the 20g but on the cheap side. Decided I would go with a holset turbo. Capable of making good power and still spooling quick. Also very cheap. These turbos are off the cummins diesel motor and sell for around 250-400 used. These turbos are also capable of taking quite the beating. Diesels can run 40+psi. After looking locally and online/ebay I stumbled upon a few wrecked dodge diesel trucks in the junkyard. The trucks were wrecked so the motor was still good. Found a nice holset turbo that seemed to be in good shape. Also it was what i needed having the T3 exhaust flange and 3" vband exhaust adapter stock. Spent a few hours on it today pulling it off and ended up buying it for $45. It has 200k on it but only a tiny but of shaft play, which im sure is just cause it has no oil in it. Started tearing it apart tonight and cleaning it up, if everything goes as planned I will be installing it on saturday or sunday!
The turbo is a holset WH1c. 8 blade, 56mm inducer capable of flowing up to 52lb/min. Should max around 500whp. I will be using the stock 12^cm divided T3 housing which should give full boost a touch after 4k. I could use the dsm flanged bolt on housing which would decrease spool time by 5-600rpms but doesn't work with my setup. Enjoy the pics.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-23-2009, 12:27 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: New turbo from the junkyard
Badass... That'll be fun on the DSM... They make some crazy power on the diesels with those things...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-23-2009, 08:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thing is massive!
(Nice triple post BTW)
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-27-2009, 01:32 AM
Holset powered 420a
Holset was installed today. Had to cut and reweld the flange on the manifold to allow the compressor housing to clear the radiator. It barely fit with this manifold. Also has to chop off my wastegate extention and reweld it a little bit higher. Overall it turned out pretty good. Took about 4-5 hrs to complete everything which isin't to bad. Have a few exhaust leaks but those will get fixed this week. Pulling the manifold back off this week to wrap the manifold with heat wrap, should help cut down on some of the heat in the engine bay. Also the manifold is starting to look bad with finger prints burning into the stainless. The compressor housing is not setup for boost reference yet so the wastegate was not hooked up yet. The turbo spools a little bit slower than I would have liked. 10psi at 4k then shoots up pretty quick. Full boost by 4.5k probably. I was still running 2" pipe on the hot side of the intercooler and didn't have enough 2.5" to replace it with yet so had to use a lowes plumbing coupler to reduce the compressor down to 2". Ended up blowing it off when hitting ab 20psi real quick so that will need to get fixed tomorrow also. Planning on doing some tuning this week and messing with timing some maybe getting it to spool a little quicker by pulling some timing in the spool areas of the map. Pics will get posted up soon.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-27-2009, 03:05 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Sweet deal man. I hear nothing but good about Holsets on Tuners. I'm guessing you didn't take the compressor nut off this time. Should be a nice setup once you get everything right. Post up pics soon please. I will have some updates on my Spyder soon.
I'm glad your keeping your lips lubricated in these cold conditions.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-14-2010, 08:40 PM
steviek's Avatar
steviek steviek is offline
i really hope this turbo hlds up well for you.. its about time your luck changes
ps is your car getting dynoed? fb stalking
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-14-2010, 10:40 PM
ned032002's Avatar
ned032002 ned032002 is offline
That turbo cleaned up really nice btw. I can't wait to hear the hp increase from the new turbo.
Old 01-15-2010, 08:31 AM
Holset powered 420a
We were just messing around with the dyno yesterday. My car only put down 270whp on the 20g. Which obviously is wrong, low boost hp seemed accurate but the dyno doesn't want to read over 270 for some reason. Its rated up to 450 so there is something wrong we have to figure out with it. Tried putting a camero on it to see if it peaked at 270 also but had some issues and by the time we worked them out we didn't have time to run it again. Next week hopefully everything will be straightened out and ill put the car back on there. Its only at 23psi right now, need to finish tuning it, its running 11.0s under boost and I have pulled 5* timing that I need to add back in. Still pulls like a MFer. Ill put some pics up after class today.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-15-2010, 10:25 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Originally Posted by SilvrEclipse View Post
We were just messing around with the dyno yesterday. My car only put down 270whp on the 20g. Which obviously is wrong, .
Nope. I made 272whp on a 20g years ago. My tune/AFC/fuel delivery were all suspect.
Kris
2012 Genesis Coupe 2.0t
Old 01-15-2010, 11:58 AM
Holset powered 420a
The car put down 340whp 312wtq about 2 weeks before that on 23psi. And that was with the 2.5" exhaust and cast manifold. That was changed out to the tubular manifold and full 3" exhaust before putting it on the dyno again. Both at mustang dynos BTW
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-15-2010, 12:07 PM
I'm just pointing out that the number isn't "unusual" as HP ratings are MAX ratings. Hell, my SCM61 is rated for 600. I do not make 600.
Kris
Old 01-15-2010, 02:33 PM
Holset powered 420a
Here are some pics of the holset installed. Still need to get some more wrap and finish the manifold and wrap the coolant line but its getting there. Need to install the new clutch and then hit the track with it. Going to max out these 650 injectors, still running 2" hot intercooler pipe that I need to change over to 2.5". That will have to wait till the summer tho, sure thats killing the top end of this car. Let me know what you guys think
Damage to the 20g wheel. Surprisingly the housing is fine, turbo could be repaired with a new compressor wheel.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-15-2010, 02:36 PM
Holy hell that's tight fitting! Is it touching the rad?
Kris
Old 01-15-2010, 02:51 PM
Holset powered 420a
Not anymore, on the top of the compressor housing you can see where it hit a few times but I pulled the rad forward a little and now it has about 1/4" of clearance or so. Its very tight
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-15-2010, 02:54 PM
I'm interested in what your coolant temps do with that bad boy. Sounds like you're thinking in that direction already, though.
Kris
