Old 12-22-2009, 12:00 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
new struts.. alignment?
hi again. im about to replace my front struts and mounts, and i was wondering how important it is to get an alignment right away. would i be able to go a few days without one? i wont be driving much anyway seeing as my transmission is pretty much shot. so would it be ok to wait a few days? thanks
Old 12-22-2009, 06:24 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Re: new struts.. alignment?
I just got mine done and afterward they said the alignment wasn't horrible, but bad enough that the job needed to be done. If all you're doing is changing out those, I'd bet that a few days really wouldn't hurt much if anything; you're fine.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 12-22-2009, 06:30 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Have an alignment done as soon as possible after you replace the struts. A few days probably won't hurt anything. But don't wait too long as a bad alignment can cause a lot of issues.
Old 12-22-2009, 07:51 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Yeah, you will need one, especially if you have camber bolts in the front.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-25-2009, 05:20 PM
CrazyHorst CrazyHorst is offline
My suggestion is to mark the camber bolts with a punchpoint or chisel line (something that won't get erased like a sharpie mark could). Make measurements of tie rod end threads if you take those off with a 6" scale to 1/32".
Install back to those same settings. After that I would not worry about the 2-3 days of driving until you can get a proper alignment.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 12-26-2009, 03:16 PM
TDWPgtp's Avatar
alright thanks guy. ill probably have one done a day or two after i was just wondering in case i didnt have time. thanks again!
Old 12-28-2009, 04:41 PM
My original post wasn't clear enough. A better term would probably be a "matchmark" where the fastener and the surrounding metal are marked at the same time.
A paint mark would also be suitable if you let it dry and take care but I've also rubbed those off accidentally when wrestling with parts.
You could also use a carbide tipped scriber (or really anything sharp and hard enough to scratch the metal) or a dremel tool. The possibilities are wide open.
2009 G8 - GT (46k)
