4X4 help
1992 S-10, shift it in 4X4 and the little 4WDH lite came on but the diagram with the wheels, stayed in 2WD and I had no 4WD, any idea what I should look for?
Thanks Joe |
Re: 4X4 help
If you shift into 4WD LO does the 4WD work? If not, try this: With the engine running, transfer case in 4WD, there should be manifold vacuum at the actuator and the cable should pull in. Post your results.
You have to know how it works, to figure out why it doesn't. |
Re: 4X4 help
Does not work in Hi or Lo, I'm sorry but I don't know what a Actuator is. I will try testing as soon as I fine out. I looked for actuators, and I don't know if I even have one on my car, I don't have the buttons on dash, I have the 4WD shift on the floor.
Re: 4X4 help
Say 98 up but may help you know what it is and what they do.
http://www.automotiveforums.com/vbul...d.php?t=572914
Re: 4X4 help
The actuator old_master is talking about is located under the battery, you have one for sure. When you shift into 4wd(hi or lo, doesn't matter) the vacuum is applied to the actuator to lock the front differential so your front wheels engage. Usual problems are the vacuum apply solonoid, located on top of the transfer case, the vacuum lines can be damaged/kinked/corroded, or the actuator diaphram is torn/cracked and will not hold vaccuum to lock the front differential.
Like old master said, check for vacuum at the actuator, under your battery, when you shift into 4wd, there should be vacuum there, if there isn't you have to see why is not getting vacuum. If you have vacuum at the actuator, check the actuator, or the cable to the differential. MT's refernce is a great write-up on these sytems and gives you an idea how this sytem works, worth taking a look at. Hope this helps. |
Re: 4X4 help
Thanks guys, its going up to 50 today and sunny, I will work on this sucker today.
Thanks Again Joe |
Re: 4X4 help
It was a vacuum line, old dried up and broken off, I didn't have any line so I started cutting a rerouting and got the 4X4 to work but I broke off a fitting on this big round ball on the passengers side inside fender, I put a screw in the hose for now. I also had a problem with the A/C http://www.automotiveforums.com/vbul...d.php?t=969349
Thanks Again Guys Joe |
Re: 4X4 help
Glad you fixed it. The "big round ball" is the vacuum reservoir for the 4WD and the HVAC, (Heating, Ventillation, Air Conditioning) systems, it needs to be repaired/replaced.
