Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-22-2009, 09:04 AM
kappy1 kappy1 is offline
2001 camry rear wheel bearings
hey all I have a loud screaching noise from the back wheel, i have a feeling it is the wheel bearing, car only has 43,000 on it, reason I believe it is this, only happens after the wheel heats up, and I replaced the rotors, caliper 1 side, and pads, very loud and annoying, also in the front,
one tire spins freely, and the other has some drag, any suggestions with these issues thanks for the input
Old 12-22-2009, 02:43 PM
artbuc artbuc is offline
Re: 2001 camry rear wheel bearings
Might want to see if drag/noise is coming from emergency (drum) brake shoes.
Old 12-22-2009, 03:53 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
The drag may be coming from a bad/stuck caliper too.
But generally, this sounds like a brake problem, not bearings.
Bad wheel bearings will rumble all the time, not screech only when hot. Also, bad bearings sometimes will change the tone of their rumbling under hard cornering.
Old 12-23-2009, 07:03 AM
yes I guess it could be the caliper, seamed to be a little tight, that is the side I did not replace, laid up right now, had wrist surgery, so it is going to have to wait, or go to the garage, plus cold and snow here, thanks all
