Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-22-2009, 08:22 AM
MtEric S MtEric S is offline
Honda Tech's-Ventilation system problem
I own a 2003 HCH with a manual trans.
I assume all HCH have the climate control System.
The heating system has some issues that can't possibly be normal.I bought this car used and this is my first real winter in it.
First issue; When car is ice cold and fan set to "AUTO" it will blow out ice cold air at full speed. I have to assume there should be a sensor telling it that the coolant is cold? Very uncomfortable...
Issue 2; Once up to operating temps the system will continue to blow HOT air until it's like a sauna before it turns itself down. I have to turn the temp knob all the way down before it is bearable, if you turn it up again even just a few degrees it becomes a sauna again
I just can't believe it's working correctly.
Anyone have any ideas as to what is malfunctioning?
I'd prefer to not pay $105/hr for diagnosis fees
Thanks in advance.
Eric S.
Old 12-26-2009, 10:28 PM
somick's Avatar
somick somick is offline
Re: Honda Tech's-Ventilation system problem
Check the coolant for air packets.
Check the coolant level.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
