Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-21-2009, 04:56 PM
spitbits1500 spitbits1500 is offline
Send a message via AIM to spitbits1500
Exclamation 1997 SL2 Idle Cylinder Miss...
After my '96 finally kicked the bucket with 240,000 miles i picked up a 1997 saturn sl2, one owner with 90,000 original miles.... She sat for a while obviously, bug garaged none the less.
At idle, when i put the car in drive or reverse, she *sometimes, but alot of the times tends to spit and run rough. Sometimes to the point in stalling out. with the slightest amount of throttle... again slight, she will idle fine with no problems, no missfire.
It is also getting only 20 mpg currently... Should be more? my 96 sl1 manual trans got 35-36. I was begining to think AIC? possibly sticking? She sat in a garage for 5 years, untouched... as far as fuel consumption... The temp gauge is reading only about 0-1/4 consistantly, where my 96 was always around 1/2. Faulty temp sensor? enrichening the mix thinking it's colder than it is?
I'm just throwin out ideas.
Thanks in advance,
-Ryan
Old 12-21-2009, 11:31 PM
Cat Fuzz Cat Fuzz is offline
Re: 1997 SL2 Idle Cylinder Miss...
I would begin by removing and cleaning the throttle body paying attention to the IAC passage and pintle. Next, I would replace the thermostat and the ECTS (coolant temp sensor) and connector. There are two of them. One with a single wire is for the gauge, the other is the ECTS and has two wires and tells the PCM the engine temp. It's very important on newer cars that they run at the proper temp and running at a lower temp can waste fuel.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 12-22-2009, 01:49 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
I'd first replace the ECTS and then the thermostat if the ECTS doesn't fix it. There is only one temp sensor on 1996+ Saturn S-Series.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 12-22-2009, 03:56 PM
Today I replaced the ECTS, as well as the intake manifold gasket, egr gasket, and removed and cleaned the throttle body assembly... No such luck. She's running better but not where it should be... Unknown on fuel consumption as of yet... More details to follow with that.
Old 12-23-2009, 01:47 PM
plymouthsrock plymouthsrock is offline
How do the plugs look?
Old 12-23-2009, 08:10 PM
sorry... I neglected to state the obvious fixes... I did replace spark plugs/wires swapped out coils to a known good coil... No luck.
They still look fine.
Old 12-23-2009, 08:15 PM
Old 12-29-2009, 10:51 AM
RC1488 RC1488 is offline
Type of plugs?
Wire condition?
Fireing order correct? Should be 4-1-2-3 at the coil towers.
Remove the ignition control module and clean the back of it where it meets the tranny.
How is it running now? Did you drive the car around for a little?
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 01-01-2010, 06:20 AM
Forgot to check the type of plugs... They are the more expensive NAPA choice. Wires are also new, NAPA. Yes the Firing order is correct, I did removed ignition control module, clean both mating surfaces, and are install.
Refilled tank yesterday, 25 MPG... Seems to be in the ball park now? What should I be getting? (Automatic Transmission)
It still has the miss, in gear, while it is stopped.
Ryan
Old 01-01-2010, 06:23 AM
*ONE more thing...
The collant system should be pressurizing, correct? I bought a replacement cap, as it sounded like the last one wasn't seating, the new one, same story I can hear air escaping when I squeeze the hoses.
I have a known good cap on my 96 that i will try today. No visable leaks throughout the system, and I dont seem to be loosing any collant.
Old 01-02-2010, 01:18 PM
This could be the issue. How old are they? The s-series are simple through and through. The fancy platinum and iridium plugs do not work right at all with these cars. Most times they lead to misses and eventualy non-running engines.
NGK copper plugs for a dollar or so each are the way to go. Get those fancy plugs out of your car.
