Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-21-2009, 03:53 PM
deesandvees's Avatar
deesandvees deesandvees is offline
350 heating up really fast
Just installed this '71 350 in my '81 Cutlass. Started it up for the first time yesterday and realized the radiator had a good leak in it right in the middle and it's going to overheat if I let it run. New 195 thermostat in here too. So I start it up, car runs for about 3 minutes or so and then temp starts to climb pretty quick and will definitely overheat if I don't shut it off. Gets to 220 on my temp guage and water in overflow starts boiling so yes it's definitely getting too hot.
Would the leak in the radiator be causing the problem? We keep enough water in there even though it's slowly leaking.
'87 Landau
Old 12-21-2009, 06:19 PM
aleekat aleekat is offline
Re: 350 heating up really fast
At those temps the thermo should open and at least cool it down a little. You sure your water pump is circulating water?
Old 12-21-2009, 06:37 PM
Not sure. When we had the radiator cap off fluid started movin around and sloshing out. It's a new water pump.
'87 Landau
Old 12-21-2009, 06:42 PM
maxwedge maxwedge is offline
A990 racer
Not that it's the issue but I assume the 71 engine has no ecu and sensors, so the 195 t'stat is wrong, should be 180, a bad head gasket can cause this as well as a water pump impeller, clogged radiator, wrong timing, fan clutch bad and so on.
Old 12-21-2009, 10:12 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
A stat installed upside-down will also cause this.
Old 12-22-2009, 05:20 AM
I've got the stat in spring side down.
'87 Landau
Old 12-22-2009, 08:08 AM
I would pull the stat and see what happens. Been know to get a bad new one.
Old 12-22-2009, 03:08 PM
One thing I don't understand with this Oldsmobile system compared to my Chevy is that the waterpump connects to the waterneck and the radiator does too. The waterpump connection to the waterneck looks like it would make it so water would be flowing through there all the time? And the thermostat just blocks the upper radiator hose connection until it's hot enough to open?
I.E. my Chevy just has upper radiator hose connected to waterneck and waterpump connected to lower hose and 1 heater hose. Other heater hose goes to intake manifold. It's serpentine too which means the waterpumps spins the opposite way I believe?
I guess that's all beside the point anyhow, I just don't understand water flow in these motors all that well.
You can kinda see the waterpump to waterneck connection in the photo below:
'87 Landau
Old 12-22-2009, 03:23 PM
MagicRat's Avatar
Your '71 350 has a serpentine belt? That is not original. The stock 350 wp must rotate in the same direction as the crankshaft. If its going in reverse, you may have found the source of the problem. As far as I know, there are no reverse-flow Olds waterpumps (but I could be wrong here).
As for that hose that comes out of the top of the wp and goes to the waterneck.... that is the bypass hose. As I recall, when the T-stat opens, flow through the bypass drops to near nil due to the waterflow through the main passages into the engine.
Old 12-22-2009, 03:28 PM
No not a serpentine Oldsmobile, just comparing this to my Chevy, sorry to confuse.
'87 Landau
Old 12-25-2009, 06:12 PM
Popped in my old radiator that came out of my Chevy, plugged a couple inlets/outlets in it and the car's staying right at thermostat temp. Must've been something plugged up in the old radiator I guess. The motor it had been attached to overheated which is why we put this 350 in there, so that would probably explain why it overheated.
'87 Landau
Old 12-25-2009, 06:34 PM
MagicRat's Avatar
Thank you for letting us know.
