Old 12-21-2009, 03:42 PM
67stang/sable 67stang/sable is offline
No Power to Blower motor
Hi all, I have a 97 astro van. The blower motor went 8 months ago I replaced it & it was fine until 2 months ago it only worked on med speed & then it just quit. Today i replaced the blower motor resistor cause i had no power at motor but still no power & no power at resistor connector. any help would be appreciated. thank you in advance
Old 12-22-2009, 10:37 PM
old_master's Avatar
Advisor/Moderator
Re: No Power to Blower motor
If only a medium speed works, the resistor is usually the problem. When it quit, it may have blown a fuse. Did you check both fuses?
You have to know how it works,
to figure out why it doesn't.
Old 01-03-2010, 12:53 PM
Yes I did. Update : The problem was a broken wire behind the controls in the dash. Thanks for the info
